Lotus7racer Posted March 26, 2002 Posted March 26, 2002 I am in the process of installing a Turbo Hayabusa engine to my 92 Westfield SEi Wide. The current differential (Sierra differential) gear if I am not mistaken is 3.3 or could be 3.6 (not too sure). I want to use differential rather than sprocket type bike style. Anyone out here can tell me what best differential gear ratio that works best using Hayabusa engine? I plan to go back to 13 inch tire (currently 15 inch). I also contemplating to buy a gear and pinion to Kamdiff. They offered 3.90, 4.11 & 5.11 Can someone calculate which one will be the best suited to Hayabusa. Thanks Jaime Quote
Fat Arnie Posted March 27, 2002 Posted March 27, 2002 You want a tall diff to give you top speed. Do you know the internal ratio's of the gearbox? If so take this and your wheel dia (21" on a 13" wheel) and stick the data into the gearing calculator you can download from the link page at www.the-webbs.com/k2rum/k2home.htm The Sierra diff was alos available in a 3.14 ratio which i think you will find is the best available for this application. You can get the CWP sets from Phil Stewart at Road Race Transmissions in Shoreham Kent on 01959 525105 Quote
garyo Posted March 27, 2002 Posted March 27, 2002 The bike engined cars list has a spreadsheet containing all ratios for most popular bike transmissions, including the 'busa. http://uk.groups.yahoo.com/group/bike-engined-cars/ Quote
