135bhp Vulcan X/flow c/w DCOE 40's complete
Vulcan 135BHP X-flow engine for sale fitted with twin Webber DCOE 40’S
All as per Vulcan spec (quick cut and paste from website!;)http://www.vulcanengines.com/brochure/index2.html
711M block
10.3 compression ratio
Modified Hepolite pistons +0.090” with deepened valve pockets
Kent 234 Camshaft
Maxiflow 1A head using 1.625” inlet valves & 1.325” exhaust valves
Steel rocker posts
Vandervell bearings
Alloy Baffled shallow sump  (had minor repair)
High pressure oil pump with take off for oil cooler
Steel front pulley
Full engine Balance
Modified block breather
Other Bits Included:-
Twin DCOE 40’s (rolling road tuned) c/w inlet manifold (o-hauled Jul 2002 prior to RR tune)
Carb Linkage
2 x Racetec air filter socks to suit(Install stays within narrow body bonnet)
Starter Motor & remote Solenoid
Engine mounting brackets (to accept round mounts)
Thermostat housing c/w fan switch
Aldon competition distributor 103fxy
Plugs & leads
Unleaded conversion to head (carried out by Vulcan)
Alloy “Vulcan” rocker cover in Red  (drilled and fitted for breather c/w vented filler cap)
20psi oil pressure sender  and t-piece fitted
Roger king copper Exhaust gaskets
Recently fitted:-
New water pump
New LUK clutch (for type 9 5 speed box)
Oil & filter change
New recon Starter Motor
Engine has covered 7500 miles since new install.
Has always been run on Valvoline racing 20w/50 & changed every 3000 miles
Still currently in car so can be heard and driven.
There will other odds and sods to go with engine like spare gaskets, distributor cap,plugs etc when I dig them out of the garage.
Will remove engine when sold.
PM / E-mail or Phone  07909 907596 (Gatwick Area)
I have original receipts for engine purchase which alone was alone £1800 without carbs etc.back in 1999. plus many other receipts i.e rolling road print out.
Things I’m keeping are Alternator,Throttle cables, Lumenition & Exhaust.
Although I may be persuaded to part with the Stainless Exhaust system for the right money!
£1250. ono
Now on ebay
Ebay
Hope you sell it mate, just the engine though !!!  ;)  ;)  ;)
SOLD
Subject to money arriving :D
