Dear all,
I would be gratful if anyone could recomend to me what they are using to record there in-car footage of hillclimb/sprint/circuit driving.
Do the cameras need any anti vibration function or mounting?
Apart from very expensive mounting kits - any ideas or cheaper supplier.
Any comments gratufully received
Thanks! :t-up:
a lot of people are using the Canon MV range (MV500i, MV650i etc) with good results - it also depends if you want to use a bullet camera as then you need a camera with an 'AV in' socket (which the Canons above do have)
try doing a search as this has been discussed many times in the past  ;)
