Guys.
I have just been reading Clasic Ford and there is a company called Retro Ford in Corby, Northanths advertising a TB kit for a zetec.
The kit includes
Emerald ecu
2no Jenvey 45mm TB's
4 no 45mm air horns
Single cable throttle linkage
Throttle pos sensor
Fuel rail
Inlet manifold
for £1382.00
Didn't seem a bad deal to me when you look at the price of Webers now.
I have no connection, I just thourght it may be of use to someone.
Contact no is 01536 747978
Rob
If it's the 32-bit ECU, that is a bargain, but if it is the new 16-bit unit, it is less so.  The kit is cheaper direct from Emerald, but the basic Emerald kit does not include teh Inlet Manifold.  I know, because I nearly bought a kit.
I bought a 1.8 Zetec for a Mondeo from a Ford breakers and was pleasantly surprised to find a complete induction setup as used by the factory still fitted.  I will be using that with the Emerald 32-bit unit to save some dosh short-term.
Should give me a reasonable halfway house, and I can go for TBs if it turns out to be a pile of poo, as I still have the Westfield intake manifold that I bought for the Emerald kit.
Regards,
Trevor
That will be the only good thing in Corby then. :p  :D  :p
Regards,
Trevor
Trevor
If this is the Ford unit then i think you'll find the engine power very restricted............... :down:
