Which dry sump
Im building a Megabusa and the engine should be here today. So now I need a dry sump. Besides the Westfield one is there a better quality for less bucks option that works maybe TTS?
Hi,
TTS is the sensible option in terms of price/performance....
Jon
Don't forget you will need to budget for an electric water pump with the TTS system.
Bazzer
....and pipes and conectors and braided hose and tank, soon mounts up on there baisic price....
Ok thanks, does the Westfield unit come with all the hoses and electric water pump? Or is the water pump only necessary on the TTS unit. Money aside, which do you recon is the better unit
The Westfield dry sump doesn't need the water pump but comes with everything you'll need to get it running.  People have had problems with the Westfield system which uses a belt to drive the oil pump, I've had no problems with my setup the main thing being not to have the belt too tight.  My personal preference having looked at all the dry sump setups was the Powertec kit which when I saw it 2 yrs ago looked much better made than the TTS and Westfield offerings, but I don't know anyone whos fitted it.
Simon.
I have sent an e-mail to powertec for info. looks like they are part or heavily involved with Radical. Some wickedly reliable Bhp the're getting from the busa motors.Thanks for your help.
