Flywheel resurfacing
Well If I had known that :bangshead::bangshead::bangshead::bangshead:
I'll just rephrase that to "If I had done a search" :p:p:D:D:D
:D:D:D
You're learning...
Is my 1.6 CVH flywheel the same as the RS Turbo one? ???
Just realised I could use the flywheel off the one currently in my car, having only done 14,000 miles.
Neil
Would have thought so, is the bolt pattern the same?  Is there anything wrong with the flywheel and clutch that was in the fiesta?
Bolt pattern is the same.  Do I presume that Westfield would have given me a decent one in the factory car? ???
I'll wait until I take my engine out and have a look before I spend more money on something I might not need :)
Thanks, people.
Neil
Neil, try Here they are closer to you than burtons and although I have not used them I believe they have a good reputation.
Just had a look using Yell.co.uk.  Actually, Chris... they're not.  Burton's is 52 miles.  ProTune is 62 :D
Oh well...  It seems that levelling the RS flywheel option is mute, now.  I phoned Westfield today and they said that the CVH flywheel is modified by them to take the type 9 bell-housing and that I'll need a performance clutch from a Mk2 Escort instead :arse:  I better go and exchange my RS clutch then :D
Cheers for all the help.
Neil
