samcooke Posted February 10, 2005 Posted February 10, 2005 Fiddling about in my bus and blew the fuse to the stereo, now it lights up but flashes defiantly if you try and use it. I guess it needs a code or some special button pressing combo. I've googled with no luck, anyone know where to look for these things. It's a Sony CDX-2500R. Quote
JAG Posted February 10, 2005 Posted February 10, 2005 If it's the original stereo then the manufacturer/supplier should have given you the code - is it listed in the owners handbook? If it's an aftermarket jobbie I have no idea - Sorry Quote
JonnyBoy Posted February 10, 2005 Posted February 10, 2005 car radio fitters or (if its oem) the dealer can reset it. sure its not nicked Quote
Barry Ashcroft Posted February 10, 2005 Posted February 10, 2005 Sony does not have codes so I would suggest looking on the front for a small hole to take a pin it will be a reset button (If Fitted) If no change throw it away and buy a new one!! Barry Quote
mike m Posted February 10, 2005 Posted February 10, 2005 Sorry Barry but most higher end newer sony units are indeed coded, some are easy to code and later models ones only available with specialist equipment Sam check your pm Quote
chrisbin Posted February 11, 2005 Posted February 11, 2005 So thats why you sold the westy.......stereo's are standard fit in Fishers, are they? Quote
samcooke Posted February 11, 2005 Author Posted February 11, 2005 Sony does not have codes so I would suggest looking on the front for a small hole to take a pin it will be a reset button (If Fitted) If no change throw it away and buy a new one!! Tried the reset button. So thats why you sold the westy.......stereo's are standard fit in Fishers, are they? Not standard fit, but as Fishers are sooooo much lighter and quicker than Westfields I thought I could spare a few kg... If I can't get it working you can have it for the Trev if you like Mr Bin, another bit that doesn't work will fit in just right. Quote
