CrashBangWallop Posted February 3, 2005 Share Posted February 3, 2005 I'm putting an RS Turbo into my Westie so, I need to upgrade the fuelling. I'm using my current facet pump as a lift pump to a swirl pot and then a gravity-fed, high pressure pump to the EFI. Can anyone suggest a suitable fuel pump and swirl pot, please? Plus any company suggestions/prices would be lovely? I've got a lot of catalogues but, they all mean nothing unless I know what I'm looking for I was told the swirl pot would need two ins and two outs (in from facet - out to hi pressure pump - fuel return to pot - overflow from pot to tank) I suppose the last one is in case I don't have a fuel return already in my tank. Alternatively, I was also told that I could split the tank breather pipe and use that as a return. Thanks, Neil Quote Link to comment Share on other sites More sharing options...
James Posted February 3, 2005 Share Posted February 3, 2005 Ive got a second hand pump for sale pierburg high presure originally purchased for a Rover V8 EFI so should serve the purpose, only done around 200 miles inlet is 12mm outlet 8mm £35.00 and it even comes with a mounting bracket! Quote Link to comment Share on other sites More sharing options...
James Posted February 3, 2005 Share Posted February 3, 2005 I suppose the last one is in case I don't have a fuel return already in my tank. Alternatively, I was also told that I could split the tank breather pipe and use that as a return. yes you could but remember to remove the one way valve (easy to over look) and the other thing you will have to bear in mind is that filling the car will beacome a Ba$56rd of a job as the tank cant breath. Why dont you do what I did get a pice of aly pipe from westfield and fit it in between the tank filler neck and the cap get a pice of 8mm pipe welded on to this and bingo one easy fuel return and it works quite well. Quote Link to comment Share on other sites More sharing options...
scooby Posted February 3, 2005 Share Posted February 3, 2005 I have an sapp cossie one on mine. You can pick them up for £30-£40 on the old eBay Quote Link to comment Share on other sites More sharing options...
CrashBangWallop Posted February 3, 2005 Author Share Posted February 3, 2005 Cheers, guys. I considered one off Ebay but, I didn't want risk the pump dying and starving my engine. I like the idea of the ali pipe behind the filler cap Thanks, Neil Quote Link to comment Share on other sites More sharing options...
scruffythefirst Posted February 3, 2005 Share Posted February 3, 2005 I have an sapp cossie one on mine. You can pick them up for £30-£40 on the old eBay Same here, but i got mine off a bosch dealer for £80ish a lot less than the £140 ford wanted. Quote Link to comment Share on other sites More sharing options...
