Refurbed rear calipers
Refurb sierra rear calipers - £100 outright £70 exchange plus £8 P and P
Hi I have a 1994 narrow bodied SEi, an early independant rear end with the westfield diff casing and drum brakes.
Although the braking is good enough as it is I am interested in disk brakes on the rear end.
Is it an easy conversion or am I going to need to change loads of new bits??
Not worth the hassle of changing , unless you're extremely determined.
Better to sell existing car and get an independant if its such an issue
It has been done
Dave
most escort specialist amongst others, will do a rear disc conversion. pretty straight foreward to fit
any suggestions on who to go to?
As Highwayman has said, unless you're really determined, there is no reason to change. Braking efficiency will not change much if at all. For me, braking efficiency is the *only* reason to fiddle with a set up that works. If you can make large gains in efficiency or feel, then go for it. However, when I swapped from drums to discs, I noticed no difference at all...
Thanks i'll stick with what I've got for now then
havent got a clue !! havent had anything to do with fords for years now  :t-up:
have a search, should be easy to find someone doing them
wot about weight
can i eat more pies if i go to discs ???
