gregh Posted December 28, 2004 Posted December 28, 2004 After spending 30mins + drilling a hole in my garage, then seeing an SDS drill do the same in seconds, I need one before putting up the shelves in the garage! Can anyone recommend a reasonable one? Want to spend under £100 include drill, some SDS chisel bits and a chuck so that it can take my existing drill bits. Cheapest I've seen is this, £74 for a Bosch SDS drill: http://www.powertoolsuk.co.uk/webcat....ID=1430 cheers, greg Quote
PhilH Posted December 28, 2004 Posted December 28, 2004 Looks like a bargin to me.I never had a bad Bosch product.If i hadnt got an old AEG i would get 1 me self. Quote
neilb Posted December 28, 2004 Posted December 28, 2004 You can pick them up for £30 ish - it you are not using it daily it will be good enough. ARD do one for £29.99 + VAT Order Code 450-01507 there website is acting up tel: 0870 600 6686 Quote
Gromit Posted December 28, 2004 Posted December 28, 2004 I bought the cheapo one from screwfix #94802-76 (£35) and its been a godsend doing my mates kitchen. Bought the cheap set of SDS drills/chisels as well, 22mm hole through engineering hardness brick, no problem, chisels channels in walls and breaks up concrete like you would not beleive. Far far better than a hammer drill. Quote
scruffythefirst Posted December 28, 2004 Posted December 28, 2004 So what does SDS do then? I've got 2 bosch hammer drills and they go through any size wall with anysize drill bit no problems. Quote
gregh Posted December 28, 2004 Author Posted December 28, 2004 My "traditional" drill worked fine in my old use, new house is 10 years older and it really struggles to make holes. From google: (S)lotted (D)rive (S)ystem "There was a discussion on this some months ago, and I can't remember the exact answer - but I think that the term was invented by Bosch - and is something or other in German. More importantly, what does it *do*? It uses special quick release drill bits which don't need a conventional chuck, and it drills through concrete and tough brickwork far more effectively than an ordinary hammer drill. The hammer action works a bit like a pneumatic drill rather than being purely mechanical. Decent SDS drills have settings which enable rotation only, hammer only, or rotation plus hammer. The last of these is what you use most - but hammer only (i.e. with the rotation stop applied) is useful for chiselling and cutting slots in plaster for cable runs etc., using special SDS bits for the purpose." Your average "home" drill has a hammer setting which is a bit like a device for drilling holes in puff pastry. An SDS drill has a serious mechanical design that wallops the drill bit into the brickwork. I was converted to SDS several months ago, having used a B&Q 650W drill for my holes in walls for many years. I bought a cheap SDS drill, pointed it at the wall (which had some hard bricks in it) and a couple of seconds later I had the holes I wanted. You'll never use a regular home drill again for bashing holes in walls. Quote
PhilH Posted December 28, 2004 Posted December 28, 2004 If you have an SDS and want to fit standard straight shank drills in it,you can get an adaptor that will take you from SDS back to 1/2in chuck.Great fof HSS and plaster mixing paddlesetc. Quote
gregh Posted December 28, 2004 Author Posted December 28, 2004 someone on scoobynet has had one of these for 3 years, £30 sounds like a bargain to me! http://www.argos.co.uk/webapp....=110737 Quote
steve_m Posted December 28, 2004 Posted December 28, 2004 I bought an SDS drill from Argos, about £30 or so for a huge 900w drill. I know it's a cheapo taiwanese unit but it was about the same price as 2 days hire of a similar drill from HSS so if it lasted longer then 2 days I was quids in. My Bosch hammer drill was taking 20 mins to drill one 12 mm hole in concrete (and getting pretty hot in the process), the SDS drill did about 6 holes in the same time. Quote
steve_m Posted December 28, 2004 Posted December 28, 2004 someone on scoobynet has had one of these for 3 years, £30 sounds like a bargain to me! http://www.argos.co.uk/webapp....=110737 That's the one ! Quote
gregh Posted December 28, 2004 Author Posted December 28, 2004 that's two recommendations then, off to reserve one Quote
Glen H Posted December 28, 2004 Posted December 28, 2004 We use SDS drills all day at work, Makita, Hilti, De-walt are some of the best with the Bosh range being next in line and normally very good value for money. As stated a true SDS drill has much more 'hammer' effect and normally work at slower speeds, also allowing rotory or hammer only as well ( you can also get chisel attachments etc to suit) these will always put a standard drill to shame. Gregh, do you have access to a 'Costco' card as they normally have a range of Bosh equipment, may be worth a look. Quote
