scruffythefirst Posted December 27, 2004 Posted December 27, 2004 Pinto head, just removed from 80k auto sierra so had an easy life, unfortunately its pretty mucky. Ideal for a big valve conversion while you keep your existing car running. Offers around £40 Set of 4 grade 3 pistons removed from same engine, good condition but need a thorough clean, have 20HC (high compression) on the top of them. Biggest standard size (IIRC) so good for a rebuild. Also set of standard rods (still attached to pistons) £40 the lot or £25 for each set seperately Pinto crank, comes with timing belt pulley but no alternator belt pulley. Could do with a polish before use £30 Oil pump and strainer, could do with a good clean but probably ok £5 Standard sump, smallish dent in the bottom, be good for making into a baffled big wing sump or simmilar £10 All other bits on a pinto also available apart from the block I'm open to any sensible offers - All prices plus postage (i'm just south of cambs if you want to collect)
scruffythefirst Posted January 7, 2005 Author Posted January 7, 2005 Someone must want some of this crap so up it goes again
