Drainage holes
After the second day of having to bail out the Westie :angry: before I could drive it I've decided to drill some drainage holes.
Has anyone else done this? Is there any more to it that just drilling a few small holes?
A hole or two in each cockpit ali floor are just fine  :D  :D  :D
Hole in each corner of panels should sort it
dont forget the to fit a sink plug in each  :p  :p  :p
i have holes, but i thought they were a weight saving measure  :durr:  :oops:
Seconded...
:durr:
... on the weight saving train of thought ....
..... is it better to have lots of small holes ...or less bigger ones ????????????????????
:xmas:
lots of big holes unless they are in load bearing areas :D:D:D
actually i used this stuff for my panelling
very light weight (lighter than carbon!;) and it also has very good drainage properties.
can be draughty in winter tho
hth
OiOi
ps I must cut my nails...
Is the floor panel actually load bearing - apart from me - and is a floor required for the MOT?
It'd be a b******* if you drop something and might be a little distracting but also quite cool. Until the engine bay catches fire then it'll be quite hot :D
You shouldnt have any problems cutting a few 6mm holes in you foot well.
I have a couple under my seats with no problems.
There's something in the MOT regs about holes being within a certain distance of load bearing members !
Don't know if this applies to the Westfield  ???
Having watched this thread for several days, I am still perplexed ...... drainage holes  Drainage Holes  DRAINAGE HOLES d r a i n a g e  h o l e s  Nope, I give up
:0:0
Spoken like a true fair weather driver.. :p:D
