please help,computer problem,pdf files
Any idea's?
just had the pc updated ,new mother board and ram .
cannot open pdf files they just appear in the top corner as a small square but will not open.
I have Adobe 6 reader installed,it all used to work on the last set up ,l do not know much about the settings side of things Please help gently if poss  :durr:
have you tried right clicking and open with - it may have lost it assocation
does not have the option to open with the right click :oops:
I had similar problem just deleted adobe and reloaded it job done for me!
Barry
Can you explain exactly what you mean by this?
Are you saying you see an icon, or when you double click the icon you just get a small square?
Andy
Andy
if l now go to playcool and try to download the pdf file all l get is a 8mm square in the top left corner
Have you installed any firewall products?  The best way is to right click and save the PDF file to you pc, it sounds like a problem with file associations
right click is not a high lighted option.
yep fire walls in place ,disabled it and no change
At what point do you get the square in the corner?
Describe exactly what steps you're taking.
Andy
This could be a long thread  :D  :D  :D  :devil:  :devil:  :devil:  :D  :D  :D
Is Acrobat starting up? Does it appear on the task bar at the bottom of the screen? If so, try right clicking the Acrobat icon on the task bar and then select "Maximize"...
Mark.
I was thinking that....
Also, try right clicking with the shift key held down. That *should* give you the "open with" option in the right click menu.
This is not an option,if l go to tilton site and download the pedal box in a pdf form:-   blank screen with a little box in the top left corner,no matter what combination of shift /right mouse l still get nothing to open or change ,before it just opened !!!!!!!!!!!:0???
OK. We had all assumed that this was a file on your PC, not on a remote web page, which is why the right click thing doesn't work. It will though, so pay attention....
Right click the link, and choose "save target as"
Save it to your desk top.
If it saves and has the Adobe icon on your desktop as we would espect, double click it. If it still doesn't open, hold the shift key down, right click it, and "open with". Select Acrobat Reader from the list...
And I've just tested this myself on the Tilton web site to make sure that there's nothing wrong with their link, and it's fine...
