Have you tried the tension of any belts?
Probably a bit obvious - but a slightly loose belt can slip when it's cold and squeal. When it warms up it's OK.
Pete
ah ha:-) tighten supercharger belt!
nope still does it! :bangshead:
So it only does it for the first 5 mins from cold? Like the same amount of time it takes to fully open a thermostat? So try replacing that?
John
John
yep try that first, or is it air in the pluming??????????????
IS it the supercharger ?
That's the trouble Ash, Richard hasn't tightened the Supercharger belt enough.
I used to get this on my'n till I tightened it really tight  :D  :D  :D
Well if its not the supercharger then try the diaphram in the fuel regulator.  Mine did it!  Sometimes it will go after a few miles. Have a word with FSE (assuming it originally came from SBD) on 01784 493555.  They repaired mine.
Keith
Simple solution - put some ear plugs in until the temp gauge reads 90
Why not try to get it to whistle a tune that you like.
Perhaps you and your passenger could join in, a sort of Westy trio as you blast along
