Interent Explorer
How do you stop your computer storing internet history / deleat existing histroy ???
Windows XP............. :suspect:
Caught browsing dodgy pr0n sites again Andy? :)
Tools -> Internet options.
There's a 'Clear History' button, and a number of days to keep history.
There might even be an option under 'Advanced' to tell it not to keep anything.
Andy
Click on the Tools menu and goto Internet Options there should be an option on there to delete temporary internet files.
Not sure how you stop storing the history. You could try TweakUI, it has paranoia settings that allow you to delete the history when you log in and out.
TweakUI
Edited to add:
Bowing to superior knowledge :) you can also set it in the advanced tab without TweakUI
Andy
Such a suspicious mind............. :bangshead:  :bangshead:  :bangshead:  :oops:  :down:  :bangshead:  :bangshead:  :bangshead:  :D  :p
Does Tweaky work in XP?
Worked for me. There seems to be different versions though so make sure you get the right one.
The link I found was to the XP version.
Wickid... innit :t-up:
I have some XP setting up to do shortly, so this has been very timely.
Seems like Nana's got caught surfing p0rn at just the right time :D:D:D
You may also want to check out the cookies, these tell a lot of stories too
set your history (time stored) to 0 days....
Bet there's a wealth of knowledge on this subject here......
Can you deleat cookies without F###ing things up..... :oops:  :suspect:  :D  :p
Without F?
Andy
Without F?
Andy
see above :D
Yea you can delete them but any stored passwords etc will be deleted.
For confidential deletion of IE history log you cant IMHO beat Historykill 2003. Not only does it delete IE history but can also be set to autodelete any files in trashcan and loads of other options. It not only deletes these log files but activly overwrites them up to 21 times making recovering the files impossible. Department of Defence specifies a 7 times overwrite to make files unrecoverable.
This is a good program to use for lots of other reasons other than covering up what naughty websites you`ve been peeking at, as confidential buisness data can be safely destroyed with it.
:D  :devil:  :D  :devil:  :D  :devil:  :D  :devil:
Also useful to go into
tools->options->content->autocomplete->clear forms
to remove things like previous searches from google etc.. :t-up:
Wayne M
