Floppy Disk Dont work!
Hi Technos,
Spent about two hours yesterday typing report.
Saved to disc (floppy). Opened file again to make changes, saved again.
Now floppy wont work, computer askes do I want to format!
Is there anything I can do before I use the floppy for a frisby and start again?
Rob :devil:
virus scan
Now thats sounds a bit technical :durr: What exactly do I have to hit ??? .
Floppy keeps tellin me it needs to be formatted, but it worked fine yesterday. is it just havin a bad day? :devil:
Rob
Sorry to hear of you dilemma, there are companies that can recover data from floppy`s that your pc wont read. Have you tried it in another PC?
In the future I recommend you buy a USB storage device to carry your stuff around with, simply plugs into a USB port and your puter sees it as an extra drive. Simply drag and drop as required. Mine was only about £16 for 16 Mb
Second that. Don't trust floppys, lost too much data because of them.
Andy
Scuze the numpty question, but isn't there a possibility that the data is stored in some temporary file on the pc if it hasn't been switched off yet  ???  ???
Good call. Try Start > Documents....
Although it'll probably ask you to insert the disc, if it isn't currently inserted. Worth a try though...
It may be worth getting a copy of Norton disk doctor and having a go with that it may recover your information.
It works for me sometimes.
Tell me you didn't save the only copy onto the floppy?
:durr:
Andy
Try a floppy drive in another machine. Sometimes read/write heads can be misaligned. Floppy's are a bit agricultural.
It would seem so or he wouldnt be asking :oops:  :oops:  :oops:
I hadnt the nerve to ask in case he shouted at me  :sheep:
Had a word with my son in law who knows about stuff and he says...  'He would need to go to the website http://www.webattack.com/get/pcinspector.shtml and download and install pcinspector file recovery program. Once installed run this program and put the floppy in, choose "recover deleted files", select the floppy disk and find the file he wants (make sure if there are multiple copies on the disk that he gets the right one) and then copy and paste this to his hard drive. Verify the file is ok and then do a full (not quick) format on the floppy and recopy the file from the hard drive to the floppy. Then tell him to get a USB flash drive if compatible with his PC as these are much better!
Thanks guys and Frau!
Looks like itsa Frisby situation. What a Numpty! :durr:
It took me ages to write all that bulls***!
Here we go again :D
Rob
