Fuel Lines
Hi,
I managed to sucsesfully pumb in and route my brake pipes last weekend.  Good job i purchased some extra lengths of brake pipe before starting.  But after many hours of bending I think i've done a half decent job.
Next  job is the fuel lines.  I remember reading a thread a while ago that it needs to have certain appoval to pass the SVA.
Whats the best pipe to use ?
Wheres the best place to get the pipe ?
What lengths of pipe do i require as they will be routed down the  transmission tunnel ?
TIA
Steve
You should definately have done a search!
Try this for starters
A: gates seem to be a good brand that cropped up a fair bit when I was looking
B: A shop, try one that sells car parts :p
C: Work out where you want to run the pipe, tape a bit of string along it, measure string.
Talk to Steve @ SBD about the injection set up for the Duratec he will advise you as to what you need and where to put the components.
