what brakes do you use????????
hi people, looking at upgrading my front brakes to something fairly capable ???
i want to go bigger disks as well if i can but dont know what there is on the market that will fit and what calipers to go for? :(
i dont really want to spend silly money but am expecting it to be in the £500-800 mark? :suspect:
so what do others use? and pics would be great if you have any :t-up:
cheers :t-up:
Why do you want bigger disks?
The most common upgrades I've read about on here are just a straight pad swap (Mintex 1144s, EBC Greenstuff or Ferrodos seem favourites) or perhaps going for alloy 4 pots to save some weight (but this seems to need a new master cylinder too).
Andy
hi andy, i wanted bigger disks because 1, the standard ones look lost under the 16" rims:(  and 2, the car is rather fast and scares the sh#t out of me so i really wanted the best brakes posible.
:D
my mate runs cosworth front setup and that feels alot better than mine but wanted alloy calipers really:)
Blimy Darren,
My car has the old M16 fronts and Granny rears and itl stop on a sixpence.
The cars only weigh 600kg, so there is plenty of stopping power.
Id rather spend dosh, on going than stopping!    :D
Rob
Blimy Darren,
Rob
well ive got almost 400bhp so it goes well enough thanks :p  :D
stopping is the problem at the moment ???
darren
i run 285mm vented on front with wilwood dynalite billets on 16" rims you can go bigger but these are big enough.can get kit from rally design.
run 272-10mm  solid cosworth rear disc on rear ,use standard caliper  just make up a bracket ,very easy to space out.
use standard master cylinder[if using smaller pistons] and standard pads.brakes are excellent need to be strapped in tight or you will hit windscreen first time you use them.
because they bigger dont need so much effort on brake pedal.
regards pete
Wow, what u got under that bonnet then?
Rob
Rob
Looks like a Cossie in the Avatar
I thought that too, from the Avatar.
Loadsa horses!
Rob
fantasic :t-up:  thanks pete :t-up:
have you got any pics f your willwood set up? :)
cant beleive the price on that kit! does that include the spacer kit for the bigger disks?
and yes im running a cosworth block ???
believe it does ,i did not use the spacer kit made my own.
will take a couple of photo's and post them tomorrow if i get time. on nights at moment.
Darren nice loking beast, just out of interest what gearbox do you have custom type 9 or T5? is the chassis MT75 or type 9?
Karl
Quote
Have you tried a parachute ?
