I have been fitting the eyebolts for the four point harnesses.  Can get 3 to line up correctly, the fourth is about 1/4 of a turn out.  Tried a few combinations of washers but i can't seem to get the right thickness.
Does anybody know where I could get a spacer/washer thin enough or is it going to be a case of filing one down.
I used some nylon plumbing washers under mine. The eyebolts don't need to be hugely tight since they work in shear.  The nylon washer will compress slightly and allows you to get a combination of both alignment and tightness.
moomin
