Discovered an engine
I have recently discovered an old engine, it's been dismantled but all the parts seem to be there.  It's a petrol engine (has spark plugs) and is a straight eight.  Inlet manifold has two flanges for what would be carbs.  Crankshaft is huge.  Bore is about 3" and stroke about 5".  Big b*******.
What's the best way to identify it ?  There are no markings on it that make any sense to me and anything that would have had a name on like the air filter housing, is missing.
Any suggestions for what might have used a straight 8 engine 20-30-40 years ago ?
Something American is the only thing which springs to mind right now.
Unless it's something like an old tractor engine ??
It may be an old stationary engine. Farms used to use them to generate electrickery and run farm workshop equipment. Same sort of thing was used for saw mills and the like, I think...
Thanks for the suggestions.  I'll see if I can take some pictures.  There is a gearbox with it, massive thing about twice the size of an MT75 and about three times the weight.
I was dreaming it might be an old Maserati engine but I think Nick is closer with a Tractor !  :arse:
Cadillac and La Salle in mind!!
Pontiac and 1937 Buick sedan in my intel
Old Alfa's (very old - think Fangio) used to use things like that. In fact, many sports and race cars of the time used straight 8's.
That said, I'd have thought you would have to be VERY lucky to find something of that calibre.
Use it to the seven and sit on the top of the 8 cylinders.
Have you measured it.
It sounds like it could replace a VX
:D:D:D
I've found that Jensen and Alvis also had straight eight engines and the capacity sounds about right.  The alloy intake manifold (all one piece too) makes me think less tractor and more car.
Try the RHOC they have been fitting engines like those for years.
:D  :D
Sounds like its about 4500cc
Has it got any sign of a diesel injector pump attached?   More than likely it's a lorry or tractor unit - so ideal for a RHOC advert!
:D:D:D:D:D
Rolls Royce Phantom used a straight 8 engine in 1950 (5.7litre) as well as Alvis in the 20s and 30s  ;)
