Fitting Smiths Telemetrix Gauges
I've just received a set of Telemetrix Gauges in the post - after 8 weeks wait. I can't believe the factory shuts down for a month!
Anyway, each gauge has an o-ring around it. Is this needed for fitting? With the o-ring on, the gauges seem to be poking out of the dash a bit too far. More noticeable on the small gauges than the speedo/tach.
Can I ditch the o-rings safely??
Kev.
The O ring helps waterproof them, so that water can't seap behind the gauge into the electrics.  If you leave out the ring then you'll need to use silicon etc to waterproof them
