twin choke sidedraught carbs for sale
Folks,
Pair of DHLAs with 35mm chokes (set 5 in the photo link below) -  £160
Set of 50mm deep pipercross foam filters to suit above £25 (includes a set of ram pipes cut down to 30mm to suit these filters).
They can be collected from Coventry area or buyer pays p&p.
Pictures for all the above at: http://sgilks.users.btopenworld.com/carbs/
Prior to use I would always recommend a strip and rebuild to replace the fuel pump diaphragm, o-ring seals and needle valves so please build this into your plans - a kit to overhaul a pair of carbs is ~£20 from Paul Mattey sportcars (available elsewhere as well) and takes about 40mins with no special tools required.  Also, unless you are an expert with carbs and engine setup then budget on a rolling road session or time with someone who can setup sidedraught carbs to give you the best from them and your engine.
More details on the carbs and selection are available at:
http://www.racecar.co.uk/dellorto/carcarburettors/dhla.htm
and
http://members.aol.com/_ht_a/DVAndrews/dellorto.htm
Stuart
07801 028138 / sgilks@btinternet.com
