davish Posted August 30, 2004 Posted August 30, 2004 i bought a part built seiw in the box of bits are two shafts splinned at each end they are 18 " long by 1" diameter can someone please tell me what they are for Quote
DanB Posted August 30, 2004 Posted August 30, 2004 Sounds like the driveshafts to me. Are there some CV joints in the box'o'bits as well? Quote
davish Posted August 30, 2004 Author Posted August 30, 2004 no it was just the shafts i think you must be right. cheers Quote
stubbow Posted August 30, 2004 Posted August 30, 2004 Yep they will be your drive shafts one is longer than the other! so caution when you fit them check manual! Quote
smithydar Posted August 30, 2004 Posted August 30, 2004 if they are the ones that came with the original kit,they will be the driveshafts you need.if you havent got a build manual the shorter shaft goes on the n/s.(ithink thats right) but they will only fit one way.side to side. darren Quote
