Help!!
I am new to all this.
I need a 4 branch manifold for my 1700 cross flow narrow body westfield SE.
Anyone got one spare or knows a good cheap place to get one made?
Any advice welcome.
Cheers, Andy.
andoid@freenet.co.uk
Hi Andy, and welcome.
No point in hinting that you join the club :t-up:
You tend to get what you pay for with exhausts. My advise would be to hang out for a S/H one if poss-or shell out to get a decent one made. So folk can assist in local company recommendations, where abouts are you in the universe?
Is yours cracked, or are you upgrading a cast/poorly made one?
Cheers, Stu :)
Hi Stu,
I have been checking ebay etc daily but nothing has come up yet! keep searching I guess.
Mine is working at the moment but is very small bore tubes, I think it is a modified escort one as it has been cut and welded several times.
I am in the Northants / Bucks area if anyone knows a place that will make one for me.
Andy.
Andy, a couple of things to bear in mind when looking at purchasing a S/H manifold for you car...
1. You may find that the 'new' manifold will exit in a different place in the bodywork-which would mean enlarging the existing hole, or cutting new one.
2. The Westfield type manifold (early one at least-not sure if later are different) will only fit if you have an inertia type starter motor fitted. This was discovered by a poor chap who bought a Xflow manifold off me off me last year. The pre-engaged type starter would require changing, and that would mean having to change the flywheel ring gear too-which means engine out...
At least with a custom made manifold, the problems can hopefully be overcome, to some extent at least.
Thanks for the info Stu,
Just one question. how do I know what type of starter is fitted to my car?
Andy
:t-up: Inertia Starter has a separate solenoid (i.e. not part of the starter). Follow the + lead from the battery. If it goes to a small square looking thingy, with other various wires going to it, and another thick wire going to the starter, it is Inertia.
If the + lead goes straight to the starter, it is pre-engaged.
Please accept my I apologys about the 'square looking thingy' description, if you know what a solenoid looks like...
HTH Stu :t-up:
Andy.
Andy, I had my exhaust manifold (not x-flow) made at Exhaust by Design based near Deanshanger / Buckingham.
Look Here
4 years on and it is as good as new.
Hi Chris,
Thanks for the info, and local too!
Do you have any idea on how much I would expect to pay?
Andy
