neo Posted July 27, 2004 Posted July 27, 2004 Yip available from my mates upgrade is the following parts from a 2.0 XE red top motor. All the below parts are from SBD and have only done about 70 hours use, all parts are like new and unmarked, replaced for an upgrade and no other reason. Exhaust cam= 10.6mm lift, 298 deg, distributorless cam Inlet cam = 11.4mm lift, 304 deg, Iskey duble valve springs X 16 Titanium valve caps X 16 All the above parts cost £600 quid looking for £275 quid or there abouts plus postage if you require them sending. reply to my email please if you can as i check it more often. Barnsy1971@aol.com cheers Rob
