.....help...this is driving me mad.
:down:......IE keeps freezing and the only way out of it is to CTRL+ALT+DEL, close it then re-open. It only started happening a couple of weeks ago but now I am lucky if it stays on for a few minutes at a time. Run Norton, Ad-ware and Spy-Bot, with no luck.
 :( ....any suggestions
re-install.
should do one every few months imo.
keeps you on your toes with backing up your important stuff too
Excuse me for being dim (crap with these bl**** things,want to get it serviced but scared at what may be found :p )
When you say Re-install do you mean use the disc that comes with the PC when you buy a new computer?? so if i done this then i would lose all programs that i have installed on it since buying it?? or am i really confused and dim :D  :D
Give me a engine any day............
Glen
Check to see if you have a folder in [Program Files] called [TV Media]... Nasty little pest that slows/locks IE called cleverIEhooker.jareid
Safe mode then delete the folder/contents, update spybot S&D and off you go.
