sqeeking noises
Squirrels? :D
Seriously though, if it is rodents  :D  or any similar small animal (I'm pretty sure that most of them would squeak if lightly squeezed) then ensure that you don't claim ownership to it. Cos, as it's a vertebrate, if it was your pet you could be liable to prosecution under the new animal welfare legislation  :p .
I can see it now...
Plod: Is this your car sir?
Pistonbroke: Yes
Plod: ...and is this your small furry, squeaky, lightly squeezed, animal sir?
Pistonbroke: Can I consult my lawyer please :D
Small children probably squeak too - blatted past a school lately?  :D  :D
I can see it now...
Pistonbroke: Yes
:D  :p  :D
Bernard !
I Thought youd been cured of ya Tinatus
:D:D:D:D:D:p:p:D:D:D:D
Had a look this a.m. need a bit of help please!
Turning the road wheel the squeek seems to have 'gone away'
but I know its still lurking in there somewhere.
So far I have removed caliper and hub.
Can't get the bearing out yet as I dont have circlip tool to hand.
If I rotate the bearing by hand there is a "noisy bit" in one spot (like the ball races grinding )
Ive inspected the caliper and upright etc. and all seems OK no visible damage signs.
Coupla questions though ....
When I pull the hub out from the bearing the drive stub axle can be moved around ( side to side ) its OK with the nut tight .
Is this normal ?
As I was removing the hub nut I inadvertantly pulled the handbrake lever hard on to stop the hub rotating .
I expected the calipers to move the pads together but was suprised to find they had not moved !
What torque setting to use for the caliper mounting bolts ?
Wessy ally uprights.
TIA
:oops:
Hi Bernie
bit late in replying cos me PC is playing up!
You should not have play in the stub axle, sounds like the nut isnt tight! IMHO.
The bearing is a tight fit in the upright, and needs carefull pressing if you are goung to remove it!
Rob  :D
Your bearing shouldn't "grind" and there should be no side to side play in the hub/stub-axle w.r.t. the upright..
Sounds suspiciously like the bearings, although getting them out is likely to b******* them even if they weren't, and even if you did get them out, you may as well replace them with new 'uns for the sake of  a few quid...
My few penneth! :D
Wayne M
