Car now sold subject to the usual.
Sorry I couldn't modify the add before today (the packers packed my pc), but thanks to all those who have enquired about the car.
:( It's too expensive to take so here goes.........
Offers please!!!!!
Starter kit bought in July 2002.
Panels fitted.
Fuel lines fitted.
Brake lines fitted.
Pedal box fitted.
Std steering rack, lower and upper steering column fitted.
Front/rear brakes fitted with a set of 5-spoke Fox Racing 15” alloys finished in Anthracite and fitted with Toyo Proxes.
Handbrake fitted.
Std fuel tank fitted with sender unit. Red top fuel pump fitted.
Wiring loom in place. It’s the standard one that suits fuel injection but has been factory modified for carbs.
Chrome yellow bodywork mostly fitted, but minus cycle wings.
Rear lights fitted.
2L zetec engine with letter from Ford to prove age for SVA. Fitted with Dunnel lowline sump, Burton steel lightweight flywheel, and alternator & mounting kit from Westfield.
Clutch and throttle cables.
Type 9 gearbox with Quaiffe quick shift lever, plus propshaft.
3.65 LSD fitted.
Raceline water rail with all silicone hoses and fittings.
Twin Webers, Linkage, Weber manifold and Wecon 3D engine management system. Fuel lines and fittings.
Catch tank.
Battery tray and leads.
Head lights
SVA approved steering wheel and boss.
Full Westfield exhaust system with heat shield.
Radiator fitted with fan.
Westfield sports seats in black with runners.
Willans 4-point seat belts.
RAC rollbar.
Westfield dash and full set of VDO gauges.
SVA cover kit.
…..and I’ll throw in some axle stands and a new trolley jack!
Parts you will need to complete:
Horn, air filter, cycle wings, aero screen, battery, carpets if you want them, indicators with pods, and side repeaters. If you don’t fit an aero screen then you will need the full windscreen assy plus heater/demister (for SVA).
You can call me to discuss on 07971 492573 or 01462 628870. I’m in Bedfordshire.
Gareth.
