Fuel Hose
Can you use the clear reinforced poly hose (available from all DIY stores!;) as fuel hose or does petrol eat it alive. I thought it would be nice to see my fuel flowing!!!
I Beleive it's a Big No No, but i'm ready to be corrected.... ???
I think someone said recently that they even had an SVA failure with proper, but unmarked petrol hose.
I know mine has printing all over it, and has lots of approval numbers as well!
Must have the proper BSA number marked on the hose, I covered mine with convulted tubing to avoid rubbing and inspector got me to pull a section off so he could check for the number.
if you use hose that does not have any numbers marked on it you will need some proof that it is ok for fuel use.
a catalogue is fine or a bill for the hose stating fuel use on it.
The reason I ask is that I have access to this hose for free and seeing as my car is already registered I should not have the "inspection" problem. The thing I was worried about was the go-go juice eating/melting the hose and f##king up my fuel filters and injectors
For the cost of proper fuel tubing, is it really worth chancing it?
if its the clear stuff im thinking of it usually goes hard/brittle quite quickly
I used some on a motor mower.  It quickly discoloured and lost most of its flexibility over two or three years.  I wouldn't use it on a car.
Contact Think Automotive Ltd for all fuel and other hose reqirements including fittings at
http://www.thinkauto.com
Keith
Quite apart from its compatibility with Petrol, you also have to consider how the hose will cope with underbonnet temperatures. In my experience polythene hose softens greatly at anything above room temperature and that coupled with the possible consequences of a fuel leak would put me off using it.
Kevin
