Hi All
At the risk of making myself look (a) young and (b) an  :arse: ,
I have bought new spark plugs for xflow - NGK BP7ES's, but what gap size would you recommend?
(now the  :arse:  bit) - when people say 25 thou, what measurement is that of? Inch/cm ??
(I *did* do a search, but it looks like no-one is as stupid as me to ask this before :D, and I'm not ashamed!!!
Will.
25 thou is 25 thousanths of an inch, ie 0.025".
Steve
Thanks - Any idea on what the gap size should be?  :D
Will.
It think that the gap for a standard x-flow is 0.7mm if you are running a sports coil then 0.8 or even 0.9mm
Hi
I have a microdynamics ignition amplfier, so presumably I could go for 0.8mm and that should be ok?
Thanks.
Will.
Generally speaking the bigger the gap the better - more spark, try it at 0.9 see how it runs, check the plugs for colour etc.. if it's a problem take them back to 0.8
Neil
35 thou with uprated ignition and 25 with normal ( in my still young,old mans talk):d
Right - re-gapped the sparkplugs last night (and I wondered why it was running a little rough (spitting and coughing etc) on Monday :D )
I had set them to .25mm   (oops, and surprised it ran at all!;)
Now set to .9mm for starters but it was wet last night so have not tested it yet.
:durr:
Thanks for all the help!
Will.
