AA Composites aeroscreen (for SE/Narrow)
£50 plus postage
For the SE/Narrow. These are no longer made.
The setup uses a low poly screen attached to short fibreglass pillars that bolt into the standard windscreen mount holes so you can swap between them (I've put the original back on mine last year). You retain the standard fillet in front when fitting. I also added the bottom black edging as it located it into the slot a bit better.
Two pics below (inside and out) when it was on mine.
