indicator lenses needed
Does anyone know what the "flat" style Lucas lens was used on?
I'm referring to one that fits on the same base as the beehive lens, like on a bugeye sprite
Somewhere, I've seen some that only protrude about 1/2"
Were they a Landy item?
edit...red ones are available for XK-120, but I want amber
If you are referring to the L488 (73 mm diameter rubber surround), then these are also available in amber.
FYI, the whole unit is different because the bulb sits lower in the fitting. The bulb holder is deeper, as is the rubber boot.
Stop/Tail Light-Complete (Flat Red Glass Lens) LUCAS L488 Type - Electrical from ESM Morris Minors UK https://share.google/CIzgUQ4uQQrInYWV7
Here's a link to the single (indicator) holders:
https://ebay.us/m/rEamm1
And to the boots:
https://ebay.us/m/uNSUcN
You could instead be refering to the Lucas L539 light that is 83 mm in diameter. I don't have a link for these but a quick internet search may bring them up.
Indeed, the 73mm is what I want.  I have modified the sockets to be deep enough, so that is not an issue.
I just need some "flat" amber lenses
or, am I looking for unicorn poo?
edit,,,Success        MM Spares has what I want
now to decide if it's worth fighting the current shipping/tariff debacle
thanks Morris
thanks Morris
Does the  shipping/tariff debacle apply to items between two private citizens?
I have no idea   but if I were betting, I'd say yes    basic govt greed
I did find some lenses over here, easy once I knew what to look for
