Malcolm P Price Posted November 18, 2025 Posted November 18, 2025 I want to buy a reversing camera for use in my Skoda Octavia and would like your comments and suggestions please. As I understanding is that there are wired and wireless ones and that wired ones give better picture quality. Some cameras have active guide lines which show the predicted car path. The display can be in the rear view mirror or a separate screen on the car's dash panel. The price range is from £15 to £500 so what are good value for money ones?? Mal Quote
Captain Colonial Posted November 18, 2025 Posted November 18, 2025 What year and mark Octavia do you have? Quote
Malcolm P Price Posted November 18, 2025 Author Posted November 18, 2025 My car is an Octavia 1.4 TSI mark two 2009 facelift model There is a tow bar with a large 5mm thick aluminium protection plate behind and I think a camera could be mounted behind this if a vision hole was made though the plate. Quote
Captain Colonial Posted November 18, 2025 Posted November 18, 2025 That probably rules out what I had in mind then, sadly. East Yorkshire Retrofits do some great products and installations for VAG products. Good luck whatever path you choose! Quote
corsechris Posted November 18, 2025 Posted November 18, 2025 I put one if these in my Midlana: AUTO-VOX V5PRO OEM Mirror Dash... https://www.amazon.co.uk/dp/B08FD2JKW3?ref=ppx_pop_mob_ap_share It’s mostly a dashcam I suppose, but the reversing camera is pretty good and has guidelines. The reversing camera was my reason for fitting it, the rest of the features are a bonus. Quote
SootySport Posted November 28, 2025 Posted November 28, 2025 VAG cars all have cameras mounted in the number plate light plinth and thats where I put mine when I had Audis. You might be able to connect it up to your media unit depending on model. I just bought a cheap camera from Ebay which had the guidlines and it worked fine. It 's great for hitching up a trailer and if you paint a bright yellow line on the centre line of the trailer hitch, it's much easier to line up the hitch with the towball, especially in bad light conditions. Quote
Paul Hurdsfield - Joint Manchester AO Posted November 30, 2025 Posted November 30, 2025 I fitted one to my Tiguan, unfortunately I’m away at the mo and all the info is at home. There is a thread on the MK2 Tiguan forum, as Sooty says you replace the number plate light, installation was quite easy, but you have to re-code the ecu. If you are ok with odb readers and so on you should enable to do it. Quote
