c20XE DTH throttle bodies.
Set of QED (Jenvey) 45mm direct to head throttle bodies, 120mm trumpets, fuel rail and ITG air filter with carbon back plate.
Long trumpets give good low down torque and these 45mm bodies will allow excellent power with the right engine modifications. I have seen 280bhp from them on a 2.3 so I know that they will flow enough for most real world applications.
The ITG filter is specially made to fit but easily available if another is ever needed. This one is around 3 years old. It's pretty big but it doesn't look stupidly large sticking out of the bonnet, just "purposeful" 🙂
There is a bracket for the underslung linkage but the linkage itself is not included. Neither are the injectors or the TPS.
£600 plus postage of your choice.
