Set of 7x13 Alloy Wheels and Tyres
Set of 4 minilite type 7 x 13 alloy wheels c/w centre caps.
Two fitted with lightly scrubbed Nankang 205/60/13 AR1 semi-slick road/ track tyres with 4.5 mm tread ( only comes with 5mm new)
4x108 pcd (ford fitment)
ET 0
excellent condition
£295
  • 2 months later...
Hi, did you have any rubbing with these on standard arches or were you running extra wide ones?
Sorry, what rear calipers do you run too? I hear minilites can catch golf rear calipers.
Hi
These are not a problem to fit on the front, assuming you have cycle wings that are suitable for 205s although the arches will have to have cutouts for the cycle wing brackets ( see pictures)
With the rear you will need rear arch extensions, as they stuck out about 30mm outside the standard bodywork .
With regard to the brakes I was running Sierra calipers so cannot give you a definitive answer as to whether they will fit without rubbing.
15 hours ago, The Machinist said:
Hi
Hi,
Much appreciated, thank you.
Mark.
  • 4 weeks later...
On 20/12/2025 at 08:13, markat said:
Hi,
Mark.
Purchased these earlier via ebay. Awaiting confirmation date for collection.
Thanks.
