just got some questions that have probably got really simple answers:
1. for sva test does front to rear fuel pipe need to be metal or will rubber/braided rubber suffice?
2. when answering the above question could anyone tell me exact spec of pipe, diameter etc and also any recommended places to buy from in west yorkshire.
3.just ordered a 2.0 zetec engine from a 94 mondeo with 77,000 miles on, what do i need to change when reconditioning for my seiw? i think i've read somewhere about changes to water pump but can't think of anything else.
any help with the above would be greatly appreciated
thanks dan
i used goodridge braided hose, not cheap by any means but passed sva, dave from db replica cobras was in for a retest, i was wearing overalls so he assumed i was from the westfield factory :D sva inspector said : no this ones been done properly ???  :0:suspect:
Hi,
I'm building a kit for racing. I intended to run brake and fuel pipe through the passenger compartment for protection from kerbs / gravel etc.. Also ease of maintenance.
Does anybody think this a good / bad idea?
I was thinking of using steel pipes and bulkhead fittings for the fuel pipe but just passing the brake pipes thorugh a grommeted hole.
Would this pass SVA?
I was thinking if I could get the car SVA'd it would be easy to run engines / brakes in etc...but I don't necessarily have to.
Thanks for any advice
Geoff
if you use any form of flexi fuel line and it doesnt have a BS number on it they may as for something in writing to say it is suitable for fuel. been told a brochure would be acceptable
