Odyssey battery.
Odyssey PC680 battery. £50.
How old odd your odyssey and do you know % of performance left?
Sorry, don’t know either.
Battery was losing charge, replaced it, and the new battery was the same. Only to find a wiring fault was causing the drain.
Similar things have happened to me in the past, hence I have a used PC680 and a PC545 (I think) in my garage. Pretty sure they are fine but not sure how to tell?
Here are the codes on the battery if that helps.
