Murraymint Posted August 16, 2025 Posted August 16, 2025 don't suppose anyone has a front set of carpets/mats for a FW that their not using, must be in good condition. Mine are getting a bit worn on the drivers side.
Kingster Posted August 17, 2025 Posted August 17, 2025 FYI mats from a ZK will also fit because it’s the chassis that matters here, not the body style 👍 1
Dave Eastwood (Gadgetman) Posted August 17, 2025 Posted August 17, 2025 To which end, it would help to say which chassis you have; most FW’s tend to use the chassis for the Zetec engine with MT75 or T9 gearboxes. So all share the same carpet set. But SEiGHT’s, Mega S2000’s, Sport 250’s and bike engined cars all have different, as the chassis are designed for bigger gearboxes, on the car engines models, and effectively just the prop and reverse ‘box on the bike engined models. What age is the car? (Although discontinued by the time FW bodywork came along, there used to be something called the Type 9 chassis, this had the narrowest of the car engine transmission tunnels, suited to the old 4 speed and later 5 speed T9 box. Thus has the widest car engined front carpets, and narrowest tunnel carpeting. 1
