deano.1 Posted April 26, 2004 Posted April 26, 2004 Came to fit handbrake cable today that came with my SDV kit but found that it has the wrong fittings, i.e the fittings that hook over the levers on the caliper are not there! Ive got the origional Ford cable but it looks too long! Any other SDV builders had this problem or have I been supplied the wrong cable? Cheers, Dean Quote
darthurs Posted April 26, 2004 Posted April 26, 2004 It sound like you have got the handbrake cable for drum brakes. Are you fitting rear disks? If so you will need to swop your cable with Westfiled for the correct one. Dan Quote
Enterpryse Posted April 26, 2004 Posted April 26, 2004 This sorta happened to me and they'd sent the wrong cable, have a peek at my website as its got some picis and measurements that might help. Stuart Quote
deano.1 Posted April 26, 2004 Author Posted April 26, 2004 Yes nice one lads, that makes sense cause i am fitting rear discs. Thanks very much Quote
david matthias Posted April 27, 2004 Posted April 27, 2004 Hi Dean yes exactly what i found because i did not tell them i was fitting discs the factory cheerfully changed it though david Quote
deano.1 Posted April 28, 2004 Author Posted April 28, 2004 Yeh i gave them a ring and theyre gonna change it! Quote
