Mat Crawford Posted July 27 Posted July 27 The build : Engine : VW 1.8 20v AGU engine - Running 262bhp Holset hx25 Turbo - New in December Forge DV valve Custom alloy inlet manifold Alloy radiator Alloy front mount intercooler 630cc Deka injectors Sytec High pressure fuel pump Uprated fuel rail Custom alloy short range fuel tank Davies Craig Digital Thematic EWP / Fan Switch Pierburg Electronic water pump Braided oil and fuel lines all round Running Gear: Type 9 gearbox - some quaife internals XR4 LSD Hi spec lightweight cortina uprights Hi spec UL4 front callipers yellow stuff pads Siltech wide track kit Siltech anti toll bars front and rear Protec Shocks - spring rate 400 front 225 rear ( rears rebuilt last year ) Compomotive CXR wheels - Toyo 888r tyres Electronics: DTA Fast ECU Race technology dash2 Race technology data logger DL2 LED lights front and rear Tecomotive CWA Water pump controller AEM Electronics fuel/Air gauge Fuel cut off switch Master power isolator Lightweight race battery Body: P-cages full roll cage Tillet Carbon fibre driver seat - FIXED 4 point harnesses - driver renewed this year Carbon fibre front nose cone Carbon fibre bubble screen Carbon fibre furl tank cover Carbon fibre cycle wings and uprights Carbon fibre side panels Carbon fibre dash Momo caterham steering wheel Everything internally has been stripped Car has been corner weighted and set up for hillclimbs but it hasn't been set up too aggressive SPARES; Spare fuel tank Set of brake pads front and rear and anything else i can find in my workshop 12 month MOT £10995 call mat 07920248938 3
Kingster Posted July 27 Posted July 27 That trailer has to be worth a fair bit! 👍 Making the car good value 😁
LoneWolf Posted July 29 Posted July 29 Nice engine 😄 How does it go in a Westfield? Yours is probably the first one I see in the UK...
Mat Crawford Posted August 3 Author Posted August 3 Goes very well in the Westfield especially at 560kg. I haven’t seen or heard of another one anywhere. trailer no longer available
