Honda S2000 Brand new - 0 miles
Westfield S2000 for sale.
This is my 2nd Westfield I’ve built.
The first being a Sport250 ecoboost.
I purchased the chassis from a club member that had got a new brand new chassis already registered from Westfield.
The car is on a Q plate - so no emissions when it’s MOT time.
This is the new style chassis that has come from the new Westfield factory. With integrated full cage mounts and reinforced diff area.
Keyless Start, fob and blip immobilisor.
The Car is booked in for a following road session the end of this month- as the Ecu only has a base map at the moment.
The car has done 0 miles as it stands.
Westfield wide body
Nitron suspension on each corner
Carbon Tillets & Tillets bases
Aim MXG dash
OMP steering wheel
Go Race QR steering wheel
Carbon nose
LED lights
PDM -BCM
13’’ team dynamics with R888’s
80k Honda S2000
New chassis
New wishbones
Simtek Body Control Module
No handbreak - liniar potentiometer (electronic)
Rad tech radiator 65mm Spal turbo fan
stainless steel radiator brackets
Ash coolant pipes
Black powder coated alloy coolant pipes
Carbon rear aero
Carbon rear arch protectors
Carbon msa covers
Wilwood front calipers
Mintex 1144 pads
AP racing master cylinder
Updated clutch master cylinder
Golf rear calipers
Carbon tunnel top
Carbon sides
TRS 4 point harness’s
LSD
New starter motor
New alternator
Msa rear roll bar
Wide track front wishbones
A P Carbon show Quality Nose
A P Carbon headlight shells
A PCarbon indicator pods
A P Carbon Dash
Windscreen
Odyssey battery with cradle.
Stainless exhaust system
Bosch lambder sensor
Stainless break lines
Ram Air filter
Bosh fuel pump
DEL Laptop for BCM and ecu control & necessary cables for connection.
The car wants for nothing, Every nut and bolt brand new, every mount bush etc.
The Honda Engine and box was at 80k when I took it out the donor.
The Aim dash was set up by Aim last week, to make sure the sensors & maths was correct.
Any Questions please message me.
£offers over £20k
  • Like 6
Stunning car, GLWTS!
  • Carl Warren changed the title to Honda S2000 Brand new - 0 miles
I am open to offers guys, talk to me .. see if we can work a deal out.
