Tim-s Posted July 16 Posted July 16 2016 WESTFIELD SEIW 2.0 BLACKTOP ZETEC ### DEPOSIT TAKEN ### I’m selling my beautiful condition Westfield as I’ve had the opportunity to purchase another car. So this is a very sad post but moving on. 2016 on age related plate New crate engine from Westfield with certificate and covered only 13700 miles. Omex Throttle bodies on Omex 600 ECU Larger green Bosch injectors Stainless steel exhaust and foam air filter Regularly serviced and just had all filters & cambelt and water pump done Just Had another oil & filter for new owner with 5w/40 fully synthetic millers oil. Mapped and made a very easy and safe 179bhp with Dyno certificate Type 9 gearbox been fully overhauled with short shift and new saddle fresh and correct oil just changed. Ford 7.5” Cosworth diff 3.64 ratio with brand new LSD unit fitted and setup by Bara Motorsport Independant rear suspension with new bushes and fully powder coated arms New spax coilovers with progressive rear springs and drives beautiful on the road. Wide track front suspension with new spax coilovers new bushes all powder coated and looking like new. All geometry set for fast road use RACELINE lowered sump Powerlite starter motor & alternator Alloy uprights front and rear lifeline fire extinguisher Lowered floors LED headlights Turbo seats on adjustable runners with blue 4 point harnesses Momo teams steering wheel with B+G boss New AGM light weight battery High level brake light Westfield guages with digital volts and USB port all working Hi-spec / Westfield Uprated brakes all round new discs with mintex M1144 pads all round The car wants for nothing and had a big recommissioning over 2024/2025 Any inspection is welcome I have a ramp at home so can be viewed on the underside throughly. Car was purchased in 2021 from Toybox so has a good pedigree Comes with full weather gear roof and doors and also genuine Westfield wind deflectors I’m sure there’s lots I’ve missed so chatting would be best. Folder full of history £15000 PM me in genuinely interested I have a walk round detailed video of the car that I can’t post as the file is too big but can forward directly. TEL….07969 812927
Naranja_Al Posted July 16 Posted July 16 @Tim-s you need to include a means of potential buyers outside WSCC contacting you. The For Sale section is a public part of the forum and anyone who isn’t a member can’t send you a DM. Suggest a mobile or email address. GLWS 👍
Flying Carrot Steve Posted July 16 Posted July 16 14 minutes ago, Tim-s said: Thankyou for the heads up I’ll add a mobile If you have a YouTube account you could load the video there and then put a link up.
Tim-s Posted July 16 Author Posted July 16 No unfortunately not I’m sure my son has though Thanks for the info 👍 1
