JTR Posted July 15, 2025 Posted July 15, 2025 Hi. Does anyone have a set of unmolested rollbar covers to cover the base of the rollbar as it attaches to the rear of the chassis? I think NV Carbon used to make a carbon set but I also think they are no longer in business. Westfield want £268 for a pair and this is simply ridiculous. What other options do i have? 1
Flying Carrot Steve Posted July 18, 2025 Posted July 18, 2025 On 15/07/2025 at 16:27, JTR said: Hi. Does anyone have a set of unmolested rollbar covers to cover the base of the rollbar as it attaches to the rear of the chassis? I think NV Carbon used to make a carbon set but I also think they are no longer in business. Westfield want £268 for a pair and this is simply ridiculous. What other options do i have? Do you have any pics please? I can't visualise the part you mean.
Flying Carrot Steve Posted July 18, 2025 Posted July 18, 2025 I see what you mean! Crazy prices for such a small item. I will ask someone I know if they can make some in carbon.
Craigieboy Posted July 18, 2025 Posted July 18, 2025 If it's just to tidy up the gap where the bar goes through the tub, would something like this do? https://www.easycomposites.co.uk/high-strength-carbon-fibre-sheet 1
Flying Carrot Steve Posted July 18, 2025 Posted July 18, 2025 Or maybe it's a good item to be 3D printed?
JTR Posted July 18, 2025 Author Posted July 18, 2025 I think there maybe a mofast designed 3d print file on here somewhere. 1
Flying Carrot Steve Posted July 18, 2025 Posted July 18, 2025 I reckon @Ian Kinder (Bagpuss) - Joint Peak District AOmay know? 1
Ian Kinder (Bagpuss) - Joint Peak District AO Posted July 18, 2025 Posted July 18, 2025 2 minutes ago, Flying Carrot Steve said: I reckon @Ian Kinder (Bagpuss) - Joint Peak District AOmay know? Correct, he's just typing........................... 1
Ian Kinder (Bagpuss) - Joint Peak District AO Posted July 18, 2025 Posted July 18, 2025 I made mine out of this - 1mm carbon fibre sheet Here's my template. check for size in paper first. Carbon fibre roll cage foot cover.pdf Cut with a Dremel and stuck to the fibreglass with 3M VHB Tape. Make sure you put masking tape around the roll bar when test fitting the item as the carbon fibre edges can scratch (don't ask how I know). Make the slit with a fine hack saw blade. 2
Ian Kinder (Bagpuss) - Joint Peak District AO Posted July 18, 2025 Posted July 18, 2025 On 15/07/2025 at 16:27, JTR said: . Westfield want £268 for a pair and this is simply ridiculous. What other options do i have? I'll even make you a pair and ship to you for £267 3
Craigieboy Posted July 18, 2025 Posted July 18, 2025 2 hours ago, Ian Kinder (Bagpuss) - Joint Peak District AO said: I made mine out of this - 1mm carbon fibre sheet Here's my template. check for size in paper first. Carbon fibre roll cage foot cover.pdf 264.36 kB · 2 downloads Cut with a Dremel and stuck to the fibreglass with 3M VHB Tape. Make sure you put masking tape around the roll bar when test fitting the item as the carbon fibre edges can scratch (don't ask how I know). Make the slit with a fine hack saw blade. What I said Very neat too and you can spend what you've saved on ️ 1
Greg Blair Posted July 22, 2025 Posted July 22, 2025 There some on eBay atm too! https://ebay.us/m/6KgTlc
