Hi all , new Westfield owner here , just in process of restoring it as it’s been stored for 14 years by a family member !
can someone help with identifying the body ?
it’s got the 1100 blackbird engine I believe .
also does anyone recommend any companies in the south to do work on if needed ?
thanks !
https://ibb.co/ksMMD1CZ
https://ibb.co/7NvgtzC0
The factory produced a model with the BlackBird engine, the MegaBird. Not sure if your's the case, as engines were swapped in anyway, need pictures of the chassis to evaluate.
MK Sportscars work on all kind of kitcars, they are in Braintree I believe.
Thanks will do ,
good point lol . I’m in reading area , but don’t mind abit of travel !
Hi I cant offer much help with the bodywork but live in Andover.
My car had been off the road for a similar amount of time to yours and had a fair amount of stuff to go through to get it back on the road, i've done it all myself just takes a bit of time though.
What year is your megabird as i have a 2009 megablade which is pretty much the same car just different engine ( fireblade ) but it's a genuine car built as megablade from day one yours probably is too but some were modified to fit bike engines mines a wide body fixed rear arch if you need any measurements let me know put some pics up of your car that will also help .
There’s a Thames Valley WhatsApp group that may be able to help - I think @Jim RS is the contact.
Thanks do you do all mechanical work
I’m not sure on age is there any easy way to tell ?
il get some more pics up
If you have the v5 that will tell you or maybe any iva documents
Only from home, sorry.  Most of the chassis stuff is fairly straightforward, your engine might requite a bit more specialist knowledge though.
The tub looks like a zk fixed arch
Is it a genuine mega bec chassis ?
Take the bonnet off and take some pictures of the engine bay
That exhaust manifold doesnt look like a genuine megabird manifold like more lile blade manifold to me but i have been known to be wrong
Not sure if you're aware but you can just post your pics straight into the thread?
Sorry no I didn’t know ! Apologies I’m not great with technology!
