LiFePO batteries..
I was thinking of replacing the massive but fairly limited leisure battery in my campervan for a Lithium ion battery.. But the more I looked into it the more complex it became… currently the leisure charged off the alternator when the engine runs.. also from the solar. Also a Zigg 12 10a supply from mains when in site…    But it appears all of these are bad news and I’d need to use a DC - DC charger, and a load more complication..   Yet we fit them as a direct replacement as a battery on our cars and allow them to charge of a 45a alternator..
I wouldn't use one myself, but understand why some do if chasing weight saving.
Any particular reason?
I have a JWM one in my Carrot, it's been brilliant so far, arguably the best battery I've ever had in any of my kits. Perhaps need a full season to assess fully but atm it looks like an excellent move. Absolutely flies the engine round and starts more easily than it ever has before!
Just a personal choice, I like a SLB with a high purity lead electrodes. Never had a problem with them.
Might be having a word with JWM to see what they think...
Here is what ChatGPT said :) :
replacing a lead-acid (or gel/AGM) leisure battery with a lithium (LiFePO₄) battery in a campervan is more complex than it first appears. In regular cars, the switch seems straightforward because their systems are simpler and don't typically have multiple charging sources like a campervan does.
Here's why you need to be careful when upgrading:
Alternator Charging:
Older alternators try to charge lithium batteries like they would charge lead-acid ones. This can be inefficient or even harmful to both the alternator and the battery. Lithium batteries require a consistent charging voltage (typically ~14.4V). That's why a DC-DC charger is recommended — it regulates and optimizes the voltage coming from the alternator specifically for lithium.
Solar Charge Controller:
Your current solar charge controller may be set up for AGM or gel batteries. Lithium batteries need a different charging profile. You’ll need to check whether your controller has a LiFePO₄ charging mode — if not, it may need upgrading.
Zigg 12 (Mains Charger):
This unit was likely designed with lead-acid chemistry in mind as well. It might not reach the right final voltage or provide the correct charging behavior for lithium. You’ll want to check the specs carefully — a dedicated LiFePO₄-compatible 230V charger might be needed.
BMS (Battery Management System):
Most lithium batteries have a built-in BMS, which protects against overcharging, deep discharge, etc. However, this doesn’t replace proper charging hardware — it’s a safety net, not a substitute for correct voltages and profiles.
In summary:
Yes, it's totally possible — but you do need to pair the lithium battery with the right components: especially a DC-DC charger and a suitable solar controller. If everything is set up correctly, lithium is a great upgrade: lighter, more usable capacity, faster charging, and longer lifespan.
Would you like help selecting specific gear or checking if your current setup supports lithium?
I can show you how a DC-DC charger works, the key differences in lithium charging profiles, or whether your Zigg 12 is compatible with LiFePO₄.
I started to "study" this topic also. Foud that LiFePO4 have always much lower PEAK discharge current (typicaly 40-50-60 A  with 20A 12v battery). Then BMS shoud cut current .
Acid lead batteries are better in this . I am going to experiment , today got my first LiFePO4, will try to start differnt cars with it, and try if will be albe to move electric reverse in BEC kitkar...
Let me talk to my husband this evening. His day job is lithium ion batteries.
So , are the batteries in your cars lead-acid or LiFePO4 ?
