Expanding foam seat v2.0 - DONE!
Stuart Davis - Devon Cornwall & Somerset AO
Having tried this once, see here….
I thought I could improve on it if I tried again. Main problem was it was a little too high, reducing the gap between steering wheel and my somewhat sizeable thighs, and also the back support wasn’t great.
I could do a much better job with a second pair of hands, but that’s not possible currently, so this is where I am.
Having been reassured last time that pouring the whole lot in one go wouldn’t fill the garage with foam, I went for it! I taped the bag up as high as it would go, to cope with any overfill, and poured it all in.
Sparing you all the detail, it basically went well, filling up behind my back and around my shoulders very well, although ironically this time leaving a bare patch under my bum which I couldn’t manage to fill. At least I was low enough this time!
I trimmed up the excess from the top and sides, cut the hole for the harness, put some foam over the bare patch, glued it to a thin piece of ply to give it some rigidity and then taped the whole thing up. Finally, I added some vinyl to make it look a little better.
Beautiful it still isn’t, but it probably looks a bit better than the last one. More importantly it sits me lower in the car, giving me better clearance between wheel, hands and knees, and also has better shoulder support. You can see from the shoulder width that I’m not really built for a narrow Westfield 🤣. Having seen @Andrzejseat with the narrow shoulder support, I simply wouldn’t fit in there!
So, I think this one will do me for a while, it’s comfy and secure, and gives me a better position than the previous version.
  • Like 5
  • 2 weeks later...
Wow I am impressed that You managed to do it alone without other person pouring foam !
I had a chance recently to really hard test foam seat proper time on track and IT is day and night compared to fixed dimensions grp or carbon shell seat type.
Btw the same Day there was 3 formuła 3 cars on tests. The same foam seats "construction" . Also finished with tape. Worth to follow raster and better rather than better looking designs ;)
