MX5 1.8 Skunk2 inlet manifold and TB
Used on my turbo build and now no longer needed.
64mm Throttle body
cable bracket has been modified and the cable attachment has been trimmed to fit under a Westfield bonnet.
The IACV does not work and is just there to block the hole up. This would not come with the TB as standard.
there is a slight dent on the top of the TB which makes the adjustment screw difficult to turn but as its aluminum would be easy to fix if needed. see picture.
im after £350 and ill post to the UK for free. This is cheap when the whole thing is £860 new.
BTTT
