Westfield seiw 250 bhp xe track car
Westfield SEIW –
1996 kit, registered 01 May 1997
Complete nut and bolt rebuild 2015 – 2017, back to bear chassis re powder coat etc
Folder full of receipts going back to 1996 when car was purchased from Westfield. Very little use since, has only been used for springs and very few road miles.
The car is an absolutely stunning build, the quality and attention to detail are second to none in my opinion. Its a proper ground up professionally built car. I have been around westfields on and off for several years and not seen one anywhere near as nicely built.
The car was built for sprints and hillclimbs but i have added some parts to make it useable for trackdays such as a larger fuel tank and oil cooler and added a passenger seat, i still have the smaller fuel tank and pipework to not run the oil cooler if someone was wanting to use it for sprints again and be as light as possible.
The car has just been for a full health check at northampton motorsport after a small running issue which turned out to be the fuel pump, this included also-  map check, compression check, bore scope and all found to be in excellent condition with paperwork saying so.
Engine
All parts sourced from SBD
Vauxhall 2.0 XE
Steel crank and rods
Slipper pistons
SBD big valve and ported head
Jenvey DTH throttle bodies
Deep carbon filter plate to accommodate long trumpets
SBD 4-1 manifold
SBD Carbon 7” silencer (repacked in 2022)
SBD light weight alternator kit (replaced in 2022 and comes with a spare)
Off set starter to accommodate small light weight flywheel
Dry sump
Aluminium deep core radiator
Setrab 19 row oil cooler
252 bhp
182 lb ft
Safe to 9,300 rpm, shift light set at 8,500 rpm
Clutch / Flywheel
5 3/5 inch twin plate clutch
Lightweight flywheel
Hydraulic central release bearing
Gearbox
Quaife 6 speed close ratio straight cut sequential, geartronics flat shift box for full throttle clutchless upshifts
2.39
1.691
1.337
1.151
1.000
0.930
Diff
Sierra 7” Quaif ATB
4.4:1 CWP
Lightened CV joints
Lightened stub axles
Brakes
Front Willwood 4 pot
Vented discs
Mintex M1155
Rear Sierra
Solid discs
Mintex M1155
Floor mounted adjustable pedal box
Suspension / uprights / hubs
AVO rose joint dampers (AVO Refurbished 2022 all 4 due to 1 leaking)
Fully poly bushed
Front ARB
Rear ARB
Front Lightened cast uprights and aluminium hubs
Rear Westfield aluminium uprights
2.4 ratio Quaife quick rack
Chassis
Addition bracing added to:
Engine bay
Front of chassis
Diff cage
Removeable diff cage brace
All panelling in carbon fibre sheeting not aluminium like they usually are, literally everything is full carbon sheets, Sikka Flex bond and rivet
Detachable carbon / aluminium honeycomb composite floor
Full Caged roll cage
All cage mounts welded and sleeved to chassis, not bolted in!
Wheels / Tyres
Compomotive CXR
Black
8” front
9” rear
Avon ZZS tyres with load of life left, new in 2023
Also have some 10’ and 11’ image split rims with fresh but used michelin slicks which can be included for the right price
Bodywork
Lightweight GRP bodywork
Detachable rear section
Detachable rear wings ( currently has extra wide rears fitted, but have two pairs of standard width to go with it )
Detachable engine bay panels
Aero screen
Full Carbon lightweight Dash
Full Carbon Rear Diffuser
Misc
Carbon flat floor from back of Engine Bay to the back of the car
Bespoke lightweight wiring loom
Detachable steering wheel
Odyseey Extreme Gel Battery (New 2022)
Additional carbon tunnel top if no handbrake used
Weight in road trim 544KG
TRS 5-point harnesses
Stack rev counter / dashboard / sequential shift lights
Additional shift light on top of scuttle
Oil pressure / temp gauge
Water Temp Gauge
Full Video Recording setup with forward and driver cameras, GPS, throttle, brake, gear selected
Seriously enquiries only please.
07752503234
£16995
  • Like 5
Deposit taken
  • 2 weeks later...
