Just wondering  this difficult to get a simple clutch release bearing for a Westfield. I thought the company still selling theese. They are not available on the site. May I am wrong the MT75 gearbox was the replacement for the type 9 but they only sell bearing for the type 9 what is much smaller. Do anyone sell one of theese?
I want to reassemble my car but a simple part blocking me doing that. IMG_20250501_185554.thumb.jpg.0510220809471ebdca3d0a6942e84356.jpg
Yes,
Someone sent me the same info so may the longer pin could work.
Today I took a closer look again and seperated the spacer from the bearing. Doing this just been using a flathead screwdriver and prying apart. It was quiet easy.
Actually the spacer is a simple part, attached properly to the bearing.
I ordered a replacement part from LUK and I will try the same thing with the brand new bearing (prying apart) and will reattach the spacer onto the new bearing.
I am not sure if it will work but I will give it a try.
Will upload the result.
If it fails then I will order the new, longer pin.
Many thanks for the links! IMG_20250502_211612.thumb.jpg.77e31ba57bdb7106024947ed46c91992.jpg
Many thanks!
Today I tried to clip the brand new release bearing and its been connected properly. (after I realized the back of the bearing is not the one I need to the clutch fork)
So must order another bearing -exactly the same and will do it again. Should work but I was stupid and been ordering the wrong bearing.
Thanks for the link anyway 🙏IMG_20250506_153238.thumb.jpg.30a0101434736db09abbb0244dc35edc.jpgIMG_20250506_154130.thumb.jpg.db326608ec66b91dfbaa5014fe4fc018.jpg
Anybody knows what part is this?
found one on ebay and it says aircon evaporator 🤔
Sitting on the side of the zetec...
Positive Crank Vent (PCV). Connects with a vacuum hose to an oem intake plenum. You can vent it to a catch tank or remove and blank off with a plate.
The extension on the bearing is a tight fit (interference)looks to me like your dismantling the bearing.
i made an extension for mine but never used it.
The extension stops the bearing leaving the support tube (the bit that covers the main shaft)
