Blatman Posted April 25, 2025 Posted April 25, 2025 Morning all! The following parts have been cluttering up a cupboard at home and it has come time to have a clear out. To be clear these have all been stored in my house, so there is no rust or corrosion on any item except the clutch. More in the description. I am open to offers on all items. Prices EXCLUDE P&P. I usually send these sorts of things via RECORDED post. This is the cheapest signed for service offered by the post office but if that is not acceptable we can discuss options. Higher resolution pics are available on request. Westfield clutch/brake pedal. Originally this was the clutch pedal from a 1990 "offset" pedal box - £15 Ally cooling system header. Approx half a litre capacity. Main body excluding filler neck is 15cm tall with an outer diameter of 25cm The neck is about 2.4cm. The main water inlet/outlet are standar 32mm O/D. There is also a dash 3 fitting at the top and a dish 6 (I think) on the bottom to add clever stuff - £30 Ally oIl catch tank. 20cm tall by 9cm deep x 12.5cm wide EXCLUDING mounting tabs which are 25mm each wide 4cm tall. From the bottom of the mount to the bottom of the tank is 12cm - £30 Wilwood 0.625 master cylinder. No cap... never used BUT probably could do with a seal kit. £10 or it goes in the scrap bin Pinto/Cosworth "Super Clutch 700 Series" twin plate 7.25 inch clutch. NO FRICTION PLATES. There is some tarnishing on the internediate plates from storage but no signs of wear, scoring or pitting BUT I think a visit to a lathe to take a lick off would be a good idea. This was used but did less than 15 sprints - £150
LoneWolf Posted April 25, 2025 Posted April 25, 2025 Can I have the VDO right angle speedo drive for Type 9 Gearbox please? Collection at your door or you can send to a UK address. Please message me if that's ok with you. Thanks.
Ansoeb Posted April 28, 2025 Posted April 28, 2025 Hi, I am interested in the steering wheel. PM sent. Thanks
Blatman Posted April 28, 2025 Author Posted April 28, 2025 8 hours ago, Willy said: I'll have the wheel nuts! Regards Simon PM me some details and I'll send you some bank info...
Blatman Posted May 30, 2025 Author Posted May 30, 2025 BTTT - These will be available at the WSCC Auto-Jumble on our club stand on SUNDAY from about 10.30 - 11am depending on traffic...
